I cannot render the relection background with vray phisycalcamera but if use a camara from 3dsmax the Render is correct.
the light is vraysun, environement physical sky and backgound hdri image.
You can un-check the “Affect background” option under the Color mapping section of the V-Ray settings and see if it helps.
Just realized that you said “reflection background” - in that case you can just increase the RGB output of the background map until it is visible again, or otherwise, uncheck the “Exposure” option of the physical camera.
