http://www.scriptspot.com/3ds-max/relink-bitmaps - Relink Bitmaps v1.08.ms
Update 1.08 - Additional Feedback for users
Update 1.07 - Now includes Customizable QuickPaths for saving paths you use most often!
Vrayers,
After being frustrated with Max’s Photometic/Bitmap path plugin, I decided to write my own. However the ones I saw didn’t offer the features this one does. Some features of mine that are not included in the max-plugin are:
1. Fast Recursive Directory searching (searches my c:\ drive for missing bitmaps in less than 20seconds) - Bitmap/Photometric Path Editor will not search sub-directories.
2. Interactive Mode - With a single click, turning on Interactive Mode allows the user to click a missing map to see what object it is assigned to. Also allows the user the double click a missing map to isolate the object it is assigned to!
3. Undo toggle and other speed enhancements
4. Saveable Quick Paths for quick searching of your most common libraries.
NOTE: the missing file must contain the exact same filename as the one found, case-sensitive, if necessary or desired I will add an option for case-insensitive searching.
If you find this useful drop me an email, if you find a bug, please also drop me a line via this thread.
-Colin
Installation/Notes:
1. Load a file with missing bitmaps
2. Run script
3. Select a path you’d like to search by pressing the “…” browse button, or entering it manually
4. Press “Relink”
optional: Interactive Mode
2. Run script
3. Press “Turn Interactive Mode ON”, and wait a moment for it to load bitmaps
4. Select a missing map in the “Missing Maps” listbox to select the object it is attached to in the viewport
5. Double-click a missing map in the “Missing Maps” listbox to isolate the object it is assigned to
