I opened a SketchUp file that was created on another computer and wasn’t packed, so all Chaos Cosmos objects are missing. I can re-download the standalone objects, but not the merged ones.
What’s the correct workflow to relink or restore all missing assets without packing the original file? I’d like to avoid packing since it would duplicate objects and materials, increasing the project size from 30 MB to about 1 GB.
Thanks in advance for your help!
Dear kornilia_papadopoulou, hello.
The preferred way is using Pack Project to collect all related assets when transferring the file to another computer.
When using it you will see a message to choose do you want to add the Cosmos assets to the archive or not. If you choose to pack the file without them, the archive size should be smaller.
Have you tried this?
When you merge a Cosmos asset to the file, it is already a VRayProxy - which will be archived even when choosing
No in the shown above window.
If the two computers are connected to a common shared drive (and the paths may differ) you could use File Path Editor and link the missing textures and geometry.
Hope this helps.
Best,
TS
