My 3DPrinted Arcade, re-rendered on a new mood/scene, to test Corona 1.6 new features.
Love the new stuff !
(The last image is my reference pic of my actual/real prototype). ![]()
amazing
material white plastic sss??
The real thing (Last image), is very translucent (ABS plastic 3mm). But it´s not a desirable effect. So, the CGI one has some SSS level, but subtle. I will fix the real word thing painting it from inside. But maybe i will do a Glossy/Translucent version of the 3D one. Probably will look very cool. (But i don´t have a Resin 3DPrinter, so i can´t replicate it in RealLife). :frowning:
Tks ! Not sure if i understood the second question. "Should be able" or "Shouldn´t" ? :smiley: The Joystick is a real sanwa joystick, and works perfectly, i can even play Marvel Vs Capcom on it :wink:
Here´s my son playing doom. (He finished the gamming on that tiny thing). https://www.instagram.com/p/BRhO4r-jFwc/?taken-by=msouza3d
BUT : My plan is to reduce the shaft by 1cm. Not an easy task because it is made of steel. I am searhing for shorter shafts, the will look better on it. But this is a real sized prototype, so i can´t fake things on it, because it will not work on real life when i 3D print it. :smiley: (My first concept was made without real measures so i only have to worry about aesthetical side. But the fun part for this project is to make it works on the real life too. :wink: So i am changing the model to adapt the design to the function. (I even have the models for it from inside), batteries, circuits, etc... :wink:
Exploded view : https://www.instagram.com/p/BRXf5dujnf4/?taken-by=msouza3d
Now i´ve added SSS to the ABS Plastic. ![]()
