Hi everyone,
We have a renderbox from when we used 3ds max for renderings. With Revit advancing and now enscape we do not use it anymore. Does enscape support network rendering? The reason I ask is if it did I would certainly encourage our team to utilize the machine so that they can keep going on other things while they are rendering. I am not sure if network rendering is supported via enscape or not.
Thanks!
Enscape does not support network rendering but Enscape does support rendering over networks if you dedicate a single graphic card. While a dedicated graphic card will batch render I would anticipate the frame rate will lag when navigating in real time.
Hi Phil,
Where I can find more information about the “Rendering over networks” please ?
Thanks!
You’ll want to Google “Dedicated GPU Instances” or similar. Reach out to someone at NVIDIA. It’s not cheap, it doesn’t save time and money, Frame rate will lag if you’re trying to navigate real time. But it technically works.
Okay thanks for the info! Is there some plan for Enscape to include a network rendering features ? Like having a computer sharing is ressources as a “node”.
Due to the GPU outage, we can’t have enough machines ready to render.
I can’t speak for Enscape development but network rendering would seem to be a distraction from a workflow and development standpoint. The value of Enscape is that it runs side-by-side with the design application as a plug-in.
The reality of network rendering is that no matter how fast the graphic card the frame rate is going to lag giving a less than satisfactory result. The best use case is simply to have a laptop or workstation that is sufficient to run Enscape.
The other value of Enscape Is that (ironically) it often removes the need to render still images all together. Rendering, exporting and preparing still images is time-consuming and it is much faster simply to open the project live for design review. I know some very large architecture firms that have practically stopped creating “renderings” for meetings and design presentations.
If you are using Enscape for the purpose of creating images or animations, you best bet right now is a fast a workstation with a fast single video card. No other workflows on the horizon with Enscape. If you need to render with a machine other than your workstation, it will have to be the “old way” of manually launching a file on a separate computer and rendering it.
Unfortunately right now you can only batch render images. You will have to manually set each animation path rendering. If Enscape could prioritize a robust batch rendering system that includes the ability to render a number of animation paths, this method would actually be quite usable. Until that happens, dont hold your breath on any sort of efficient network rendering.
Another option for creating a batch animation would be to create a continuous cut. If you save the animation path as an XML file you can open the XML file and decrease the transition times between two cameras to 1/100th of a second. This technique allows you to effectively decrease the transition between “cuts” to zero. The result is a single continuous cut animation as opposed to a series of separate animation paths.
Example here:
https://www.linkedin.com/pulse/creating-long-take-animations-enscape-phil-read/
Phil, thank very much for pointing out that workaround. Hopefully Enscape will step up and come up with a solution that does not require editing xml. That workaround seems counter to their apparent priority on “ease of use”.
It should also be noted for those interested in that workaround… jumping directly between two positions can affect the motion before and after a keyframe when using smooth motion. Make sure you test this thoroughly if the specific motion you have developed on each path is important.
When creating continuous cuts it’s also good to have a buffer between cuts where the camera appears motionless for 5-10 seconds. Very important for post production. You can do this by putting two keyframes on top of each other with 5-10 seconds between keyframes. Then create the jump cut to the next pair of key frames (in the same place w 5-10 seconds rest) before the next animated sequence.
One more thing™. Very careful and specific control of the Enscape camera is impossible in Enscape (height, location, orientation). However if you turn on the Enscape camera in Revit (in General Settings), you can much more accurately control the Enscape camera from Revit.
One thing I’ve not been able to figure out is how to modify the “roll” of the Enscape camera. The camera can pitch up and down, yaw left and right but not rolled side to side in elevation. Bonus points if you can figure this out!!
