Remove all regions when going from 2D Pan to cam
When I use 2D pan with a region, and then go out of the 2D pan while in IR, it renders black. I need to manually select “remove all” regions.
Can this be automatic?
Or as an alternative the size of the region could be fixed to the VFB.
Thanks.
