Remove / occlude some areas of the Gaussain Splat?
I have a scene with a splat that I need to remove some areas. There is an option to remove the white geometry with going to a different software?
I don’t want to remove the area in the .ply itself, just for the renders.
I would like to do this type of integration:
3D Gaussian Splatting in Corona 14 for 3ds Max
Hey @francisco_seisdedos , clipping a gaussian splat using geometry is already possible in V-Ray 7.4. You just need to enable the clipping mask (see image below, step 1), add a distance texture with solid black for the object inside (step 2) as the mask texture, and add the object you want to clip by (step 3). I’ll also attach the scene, so you can look it on your own, just without the splat, as it is too big for a forum upload.
Note that you can even use different grayscale color for the mask to achieve semi-transparent clipping. Or you may use another texture for the mask (e.g. noise).
clipping-capsule.zip (223.7 KB)
Thanks so much @deyan.hadzhiev ! It work great.
Another question I have is if it’s possible to clip the splats in the camera?
Can you elaborate a bit more what you mean by “clip the splats in the camera”?
If you mean to only render the part of the splats, which are within the camera frustum - there is no readily available way to achieve this currently. Technically, it might be possible to achieve with a projection texture and the clipping mask above, but I’ll have to test if it works as expected…
I’m talking about the Near Clipping function.
In the viewport it work but I can’t find a way to use it in the camera / VFB.
Unfortunately, this seems like a bug in the implementation. I’ll report it internally for fixing.
As a workaround, I can suggest to add an invisible cube or sphere as a child of the camera, and add this object to the distance shader’s object, as shown earlier.
Thanks for the feedback.
That’s a great idea!
Have a nice day. :slight_smile:
Another question.
There is a way to add an Object ID to a GS?
Unfortunately - no, the ObjectID is not yet supported with Gaussian Splats. I will also log this internally for improvement.
Thanks for your time and patience.
