Hello ,
Why remove the Advanced DMC Sampler options from the UI in vray next 4.12 ?
Thanks you.
Hello ,
Thanks you.
Those options have been removed in V-Ray Next since with the introduction of variance based sampling in version 3.3 they are no longer needed.
Our QA engineers performed quite a lot of tests after that change and the result is either the settings doesn’t have any impact over the final render or the impact is negligible.
