Hey,
unfortunately I found another bug related to Corona.
When you use Cinema’s take system and set up a few takes and then try to rename them, Cinema crashes.
This happens only sometimes, but when it does it’s reproducible. I think I could narrow it down to Takes that change the Material used in Material-Tags.
When that happens C4D either just closes without warning or it freezes endlessly. It usually doesn’t even show that a report has been saved but there’s a file with matching timestamps in the bug-report folder so I’ll attach that.
I deactivated all used plugins but the issue was only resolved after uninstalling Corona. After re-installing Corona the bug was reproducible right away again.
The scene and bug-report were already uploaded: “1594737062_Take-Renaming.zip”
Flo
