Hello, i tried to render a curved wall but the result of the render shows only half of the surface. Is the form too complex to render it?
Dave ![]()
Hi Dave,
Can you make sure that you have set the resolution to Crop Region? It seems like you are using the default 800x600 resolution now.
Regards,
Ana
Send us the Revit file pls.
Can´t upload it here. Invalid file. How can i send you the file? Thanks for helping me:)
I’m contacting you in private message. Check your messages at the top right corner of the forum page.
Hi Dave,
The problem appears to be Revit related, as it is reproducible also with the Revit render engine.
I recommend you to contact Autodesk.
Best,
Ana
ok, i will contact them! Thank you!
