Render an animation with IPR and save the files...
I want to use the new wireframe mode in the IPR to render a 150 frame animation for a transition effect. Is there a way to do that?
Tried swapping the render engine to IPR on the render dialogue drop down but it does not work.
Be really nice to have those vray fsb buttons function in the main vray to do wires and other effects and be able to pipe it to backburner.
I can think of a manual way to do it - saving each frame after it has updated as you step through… so there is also probably a way to do it with a script - but that seems needlessly complex.
You can do a material override with a VRayLightMtl material with a VRayEdgesTex texture for color and use the production renderer - it should be exactly the same thing.
thanks mr v
