render animation fps
Dear Vantage team
when you are rendering a scene from Vantage the default fps is set to 30.
My usual workflow is to set it to 15 so that i render half frames and then I will interpolate with AI software.
This way I save a lot of time.
When rendering animation through live link using vantage UI, then fps is set to 1. If i render mp4 then the speed will be very slow.
So i have to convert to 24 and then frames to be rendered increase… and in general there is no way there to render every second frame so that i save time.
Can you please fix this.
HI digital_technologies,
We have that issue logged but haven’t been able to get to work on it yet. I will increase its priority and inform you when a fix for it is available.
Alexander
