I am having a nasty problem that is not allowing me to work properly.
On the same scene, with the same camera, with the same lighting setup, I am getting the following results for a render in one room, and for a render in the following room in the same scene, I get a totally blown out image in photoshop (but it appears as almost black in CoronaVFB).
I have a delivery in a few hours which means this is going to be delayed
Kindly check out the images, this started happening after I imported some objects in the scene, although I checked for albedo on the imported items and all materials got passed by the corona converter.
Thanks in advance for all your help,
R.
PS: I edited the post and added another example.jpg to show how the black dots start taking over the image in a rather organic fashion around some areas until it all goes black (but with superhigh values in the CoronaVFB, and thus white in photoshop).
Moving this to bug report.
Is this max 2016? Because it could have added automatic exposure IF you have a physical cameras in the scene. If yes, disable it.
Nope, no physical cameras.
I’ll track this on the bug report.
if I have a scene, I can easily fix whatever is causing this
You’ll find a download link on a personal message, thank you.
I’ve just got those QNAN and INDO pixels myself too. Build jul 29. It was very simple scene, just one plane with displacement. I was doing various tests and suddenly bunch of black pixels infested VFB. Those pixels stuck in same location no matter what. Even after reloading scene. Erasing VFB helped to get rid of them.
Can’t reproduce it unfortunatelly.
Is there a switch to turn off displacement across the scene?
I’d like to give it a go if it would be possible.
I found out that by turning off ALL my glass things go smooth again (but of course it is useless - we all need a little glass in our lives
Yes, there is: Render settings>Common parameters>Options>Displacement
Well, I gave that a try but it is still happening
PS: Found the Culprit - One shelled glass box. For some reason is behaving destructively across the scene. Erased it and now it is fine.
