Render colour primaries
Yes, exactly.
Is adding quick setups for workflows involving other colour gamuts in the planning? It seems like when we are finally creating UHDTV content - we will have to switch between these settings (possibly on a per job basis).Yes, as these workflows are becoming more popular, we are working to make switching between them easier.
Here you talk about Spectral colour space - and using sRGB. Does that mean you are using a combined approach of calculating wavelengths of rays and RGB values for rays? or is spectral meaning something different from wavelength calculations in this context? It seems that the term spectral relates to quiet a lot of elements of the Vray renderer (like refraction dispersion) - so would definitely be keen to find out more.Normally, V-Ray treats all colors as triplets of floating point values; for the most part V-Ray doesn’t really care what the three numbers actually mean. However some calculations in V-Ray are based on light spectra; the conversion of these spectra to floating-point color triplets assumes that the three numbers mean something specific - a color in some predefined internal renderer color space. This means that when converting from Kelvin temperature to RGB colors, V-Ray must know what that internal renderer color space is. Right now we support CIE and sRGB and we plan to support a few additional ones like ACEScg. Additionally, V-Ray may assign a specific wavelength for some types of rays - f.e. when calculating dispersion. For such rays, calculations are assumed to be performed for the specific wavelength only. Which makes V-Ray a hybrid RGB and spectral renderer.
