We have a problem:
Renderings of a same scene are differents with identical machines of a Renderfarm …
especially speculars gleam intermittently (it’s very noisy).
thx for help
We have a problem:
thx for help
It does not do it if rendered all on 1 machine?
I’d guess it is just noise from too low of settings.
it is not because of too low parameters, it’s work with one machine … :-{
I often get this problem because the IES lights refer to a non unc path. Sometimes the path changes by itself for IES. not sure why.
can you post a video showing the problem?
It sounds like your AA settings are too low…?
Are you using GI?
Yep, some more information and images of the problem would be helpful. Also, which V-Ray version are you using?
