render directory variables
In the Maya render settings there are variables that can be used for the “file name prefix” field. For example
%s or <scene> is the scene name, %l or <RenderLayer> is the render layer. My question is: what is the variable for a vray render element?
What I’d like to do is is use this to modify the name of sub directories.
Unfortunately there aren’t any vray variables that could be specified there.
You can specify the name of the sub-folders from “Vray Extra Attributes” but this will also change the name of the render element inside this folder.
