Render does not start
Last night I did a scene and rendered also, morning I added few objects and render does not start, stuck in GI & Parsing…!
earlier i saw some post with same problem but did not found that also.
disabled new object, few boole object used… disabled, view port object select render but no luck. there is no any complex material or scene. Any idea what else have to check…?
I wish… I show the file here… but I can not.
Thanks.
p.s.
upload also.
I waited long…!
dont have other system at home to check. went office on imac and it was fine on that. How on mac pro it was starting.
I sent video also… no one noticed that…?
on deadline these kind of things… not acceptable… sorry for that.
Which version did you use? Did you enable motion blur?
Did you use any plugins?
Using B2, latest.
have plugin but I dont think any plugin used in job.
Somehow, job is finished… last week.
I had a similar issue, stuck forever on calculating displacement. Also on R19 on Mac but on B1. That issue is now gone but others have appeared
