Render Edges
Are edges rendered possible? If so, what is the method?
You can use an Edges texture in the material Diffuse slot. It will produce the desired without any additional adjustments.
Kind regards,
Peter
Thank you for your reply. Is Vray 2.0 also possible? I could not find the relevant option.
No, Edges tex was introduced in V-Ray 3.4 for SketchUp.
Kind regards,
Peter
OK, how can edge be applied on texture image like this?
This can be done (again in v3.6 only) by using a Mix (Map) texture (Chaos Docs).
The Edges texture needs to be slotted in the Top slot, and a Bitmap texture (containing the image file) in the Bottom one. The Mix Map slot should also use the same Edges texture but with white Edges Color and black Background Color.
Kind regards,
Peter
