Render Element Raw Shadow
Sketchup 2025 latest version, V-ray 7 latest version.
I render with several render elements and never had an issue. One of the RE’s is Raw Shadow. Now it gives a distorted image. I made sure that all elements are denoised. I made a test with 2 settings, color dept 16 bit and the EXR-file is 16 Bit and color dept is 32 bit and then the EXR-file is 32 bit. The 2 files have following layers Base layer effectsResultRGB, above this layer is the Diffuse RE with blendmode Soft Light at 30% opacity. The dstorted image has a 3rd layer on top, the RAW Shadow with blendmode Soft Light at 25% opacity. This is the setting I always used without a problem. Whatever blendmode I select, there is always distortion. What goes wrong?
Hi again, @richard_vankesteren ​.
Could we take a look at the file?
This will be most helpful in this situation - to see all settings and try to replicate it in our environment.
Please use Extensions > V-Ray > Pack Project and share with us the archive via our support system.
Under Request type please choose Product usage questions or issues and paste the forum link in the description too.
Attach also the already rendered images.
Thanks in advance.
Waiting for the archive.
Best,
TS
To share with the community as well…
On one hand, I wasn’t able to reproduce the very same wrong result, but noticed in the log the following warning: [12:42:07.566] Warning : Render element Shadows is incompatible with Adaptive Lights and may be rendered incorrectly.
This is so only when using V-Ray GPU, with V-Ray CPU the render looks as expected [VMAX-5835].
So please be aware that Raw shadows/Shadows/Matte shadows render elements are incorrect with adaptive lights on GPU.
If you disable Adaptive Lights on GPU, the render looks fine again, but since this is a Optimization I won’t advice you to disable them, because Render time will increase.
Regarding the fact that you have used the very same setup through time, I will suppose that there was a CPU/GPU difference or the type of the model. The light calculations are different and they depend on the model, the light sources, etc.
On the other, some other artifacts bothered we as well, I used Sample Rate RE to examine them.
After that I compared CPU and GPU result and now could share that CPU gives a better result in your scene because of the available Firefly Removal.
See here the comparison with Firefly Removal on/off:
​Thank you for the interesting case.
Enjoy your work with V-Ray and contact us again if needed.
Best,
TS
Thanks for your excellent support. So I could choose between using CPU + RE Raw Shadow or GPU (without RE Raw Shadow). The second is significantly faster and missing RE Raw Shadow is not a big deal. But taking the Firefly removal into account and persuing the best image result, CPU render might be the better option. I guess the best is to use CPU render and use the GPU setting for all materials, textures and lights which is basically done automatically. I learned something new, thanks.
Regards,
Richard
Thank you for the positive assessment, Richard!
The GPU support of Firefly Removal is under development right now, so we will try to provide it soon.
I agree that it is a game changer.​
