for some reason the render element VRayVelocity will saved without data when saved as vray raw image file. When saving as “separate render channels”, it will saved correctly.:
Odd. Mind if you send the scene (or attach) in question so we can troubleshoot?
Added a example file
VelocityBug.zip (1.9 MB)
The info is there. You can confirm it by opening the multi-channel .exr in ChaosPlayer and going through the channels.
In Nuke, I plugged a Shuffle node to the multi-channeled .exr, set the Input to VRayVelocity, Output to rgba, and plugged the channels accordingly (check screencap). Note that when using multichanneled .exrs, the data is in the range [-1;1], while for separate files it is [0;1]. You can convert one to another with the Expression node.
For [0;1] to [-1;1]
r*2 -1
g*2 -1
b*2 -1
For [-1;1] to [0;1]
(r + 1) / 2
(g + 1) / 2
(b + 1) / 2
