Render elements always saving.
Hi all,
Is it possible to get Corona to stop saving out render elements when the save file box is disabled in 3dsmax?
We do a lot of test renders without always saving a file, but the render element paths are still active and will save out.
As a workaround, I have been running a script the strips all element paths, but sometime you forget and all elements from previous jobs are overwritten.
Any ideas?
Thanks.
Try this piece of script (save your file before :wink: ):
re = maxOps.GetCurRenderElementMgr()
for i = 0 to re.NumRenderElements()  do re.SetRenderElementFilename i ""
Why not just use “Iterative” (not “Interactive”) mode for test renders? No files are saved at all, even when output is enabled.
Good Luck
