my render elements don’t stitch after using strip rendering.
any ideas what could be wrong ?
thx alot,
bernhard
thx alot,
bernhard
Nothings wrong, it just doesn’t work… See Vlado’s post midway down this thread: http://www.chaosgroup.com/forums/vbulletin/showthread.php?t=43119
holy…
uuahhhh… that’s really to bad…
thx for the info,
bernhard
Can I confirm that an image rendered straight out (without elements) will work though…after looking at the link you provided Im thinking this is the case ??
I haven’t tried it myself in a long time but it remember that it did work. Reading the post however it seems you need to use the max FB and not VRay FB (can’t recall which one I was using). Anyone else?
Render elements do not work with strip rendering in principle. The basic RGBA image works, but you need to use the 3ds Max frame buffer.
