I’ve done a bunch of renders that require fields, but the render elements don’t have fields and they have squashed the passes into the top half of the frame.
Have I done something wrong? or are fields not supported but vray render elements?
Is this through the V-Ray frame buffer, or the 3ds Max one?
Through vray frame buffer.
The V-Ray VFB has never supported fields unfortunately, although this is somewhere on the “to do” list. It might be worth trying the 3ds Max frame buffer.
Thanks for the quick reply Vlado. Will use max buffer. Looks like it works.
