When rendering locally on the workstation and distributed the render across the render farm; with ‘Render Output’ ticked and a destination for the renders to save out to it only appears to save the beauty pass.
The other render elements save out but they are just black and only 54KB in size. This appears to happen only when rendering large images (over 5K) and across the network for a period of time.
The render elements don’t have their own save destination as I thought the ‘Render Output’ overwrites that when the render finishes. Any one else have this problem or a solution.
Still having this problem. Any one found a solution?
It happens the most when you are distributing a render, the render finishes, the outputs are all saved fine and then overwritten by the other slaves so you end up with just the beauty pass and no other channels…
It then means saving out all the channels one by one once the render has finished! Very annoying really.
I just realized that I had the exact same problem. I reported it but could not get why it happened, probably scene related.
The black files are placeholders, they get generated at some point but no data is written. Also, in my case max would just hang when finishing the render and attempting to save the elements, resolution was around 13k in my case.
I couldn’t track this down, but I’m eager to see if you guys find a solution or repro steps so it can be fixed.
I found a fix, before you render save the output as any other format and then again save as your desired format, and then render, it seems to fix the problem for me.
Rendering to EXR allows you to “pack” eacerything in just one file, so you end with “my_animation_0001.exr” and inside it you can find all the different channels, RGBA, Mattes, Z-Depth, everything you’ve created as render element, you just have to configure the output in max and it will pack everything and won’t create any additional file.
You can also use AfterEffects natively, and Blackmagic Fusion.
In Photoshop as Daniel said you need a plugin.
IMHO EXR’s are best handled with After Effects and it’s non destructive worflow, it will allow you to perform operations like Color Curves in 32 bit unlike Photoshop which is very limited in 32bit operations.
Also remember to configure your project to 32bit in AE.
Finally, you don’t have to force the gamma output to 2.2, the 32bit images saves without gamma so you can work linearly and apply the gamma you want in post, you also have the option to save it to 8bit (32 bit integer) but I don’t recommend that with EXR, you loose a lot of information.
Why do you disable compression? That compression is not like the JPG compression, is non destructive, so you can safely leave it at it’s default, it’s will make the file smaller but it won’t remove any information
EXR is a whole new world of options and workflows but when you get used to it you won’t be able to abandon it hehehe
So apart from exr files where the data is stored all in one file but need a photoshop plugin to access it. Is there a reason for this to happen? It seems random to me with regard to why, when and which file type it happens too, as I’ve just rendered 2 views of the same scene, one view saved the passes and the other didn’t. Screen shots attached.
It would be really handy to know why this is happening and if a fix is available as it’s making using net render unreliable and pointless as we will have to render the images locally and save manually which as I’m sure you can appreciate isn’t ideal with multiple images due to process overnight.
I can only confirm that there is definitely a problem with this, and it is reported in Mantis. I remember someone writing that sometimes it helps to remove all render elements, restart Max and add them again. But it’s probably not a very reliable solution.
I have faced the same problem with batch and the solution i found out was that somehow i entered elements save path, so all of them was saved to the users/—/documents/3dsmax/renderoutputs.
While all BEAUTY renders was saved to the directory I’ve selected in batch.
Hope it will help someone.
