delete please
Ok I am sorry cause I was able to fix this and there is no bug in vray with the raw elements!
What I had to do is just make some fixes in my comp in after effects:
I just had to make sure the following elements’s alpha interpretations were set to “Ignore”:
VRayReflection Filter
VRayRawReflection
VRayDiffuseFilter
In my case I didn’t need to ignore the alpha for the VRayRawLighting but when I ignored it it gave the same result so may be better to ignore it too.
then if you have a background to add under them it must be in the same precomp as your vray elements or you have to apply an alpha on top of your elements’s precomp.
Thanks for the quick update.
That was not the first time I use raw elements. I use them since a long time in fact. But in that case because my scene was a bit overexposed with a dark shader and because I have a lot of light coming from the back I could not fix the alpha by applying the beauty pass’s alpha to my comp like I did usually. But it’s good to know that I don’t need to do this at all if I ignore those elements’s alpha channel. I am even wondering if vray should output those without alpha?
Can be done but it requires additional coding. The best solution for now is to ignore the alpha channel for reflections when importing them in AE.
Ok,
Also the corresponding needed elements for any raw elements should be added automatically when adding those raw elements to avoid user mistakes.
We’ll make a suggestion about that into our system.
Might work for just the raw elements, however not for the filters or the non-raw elements. Though I’d prefer if this wouldn’t be automated, instead of that a warning in max, the docs, or both.
Yes it would be better with a warning question like: “do you want to add also those elements needed for proper rendering of this pass…” and a checkbox to stop asking for this session and remember the answer for subsequent actions.
Thanks for the suggestion guys, I’ve just added them into the feature-request-details.
Just a note about this problem so when I come again here I can remember! lol
We ca also set the alphas (for diffuseFilter, rawLighting, rawRef and refFilter) to straight so we don’t need to use the beauty’s alpha at the end. When we look on a black blackground straight alpha can look like they leave a very thin white fringe around an object, but as soon as we add another layer at the back, it’s gone and gives the same result as setting the alphas to ignore and applying the beauty pass’ alpha.
