Render Elements re-assemble issue
Hello!
During R&D we are faced to couple issues with compositing passes. We can’t to re-assemble beauty pass when compound lights and reflections. Our aim is render selected lights in separated layers in accordance with given formula
Beauty = Global Illumination+ Lighting+ Reflection + Specular + Refraction + Sub-Surface Scattering + Self Illumination where lights can be represented as Lighting1+ Lighting2 + LightingX. The same index applicable to all passes relative to mentioned lights.
When we trying to re-assemble final, getting difference between beauty and final. You can observe that in the difference I’ve pulled to image. I suspect this is the issue with semi-transparent pass should be added on a top. Could you help us please?
Many thanks!
I’m forgot, V-Ray for Maya version 3.05.04, revision 25473 from Jan 18 2015, 02:05:36
Does the cloth have a translucent material? There’s no way to isolate a V-Ray 2-sided material that I know of, other than adding the passes and doing a difference with the beauty like you did.
I think Vray2SidedMtl should work fine with the lightning pass. Could you please send the scene to support@chaosgroup.com so we could check the material set up.
Also the lights on the end of the hat can be extracted in a Self Illumination pass. Or you can enable the Direct Illum. option of the VRayLightMtl, if you want the light to be included in the Lighitng render element.
