Render Elements
would be too much to ask if vantage could support few render elements needed for archviz, like reflection, refraction, specular, shadow, GI. Just a few enough for a good composition.
thanks
Can you list exactly the (minimum) render elements you need ?
You can take a screen-shot of the V-Ray for 3ds Max render elements UI.
Greetings,
Vladimir Nedev
Some mat Id or object Id masks would also be wonderful.
I was wondering if the mat id was at least possible. This would be great.
cryptomatte and zdepth if possible lightmix :slight_smile:
Material ID,(Raw) reflection, (Raw) Refraction, Vray Dirt (ambient occlusion)
Rendering element matid is important
But in my opinion, it is more important (. IFL) to realize the support of sequence map as soon as possible.
Because this is the fastest way to make LED screen animation at present
Hello.
Here are all render elements we use for arch viz render. for us these are import for post composition.
Hope we can have their support soon. Other forum members can contribute to this.
Thank You:sunglasses:
Second this. Any updates or roadmap for new functionality?
Do we have any update on this? timeline ?
Hi guys,
We are working on adding support for render elements and they will be available at around the start of H2.
Alexander
ok great. waiting for this:sunglasses:
Hi all
We are very much pro, adding render elements in Vantage, plus the possibility to fast select objects and create black white masks.
For archviz it is important refraction filter which automatic creates mask for windows, reflection , refraction, wirecolor for selections, ids…
Hi @Alexander.Atanasov and @vladimir.nedev
Could you give is a rough ETA for the arrival of more render elements please?
Are we weeks away, or months or more?
I believe they are necessary:
-specular
-reflection
-refraction
-multi matte (or cryptomatte)
-GI
-Direct light
on which the denoiser must work.
Best regards
Filippo
Wireframe color
