Render Elements
Hi
Just would like to check, if I created a solution for an image with out render elements selected, then load this solution and rerender the image and select the required render elements will it be generated correctly or do they need to be selected at the time the solution gets generated?
They should render corerctly. i assume by “solution” you mean an IrrMap or similar. So during rendertime that solution is used to create the final image. and that is used in renderelements, not the original solution.
Kind Regards,
Thorsten
Cool, Thanks
