Render error
I have 60 renders to do at 6K spherical but got this error.
Scenes are populated with cosmos and Scatter could it be scatter not being supported?
Renders fine locally
Parsing vrscene-file error. File “/root/.ChaosGroup/vray-cloud/work/drone/jobs/99698851/1/scene.vrscene” at line 103908: expected a “=” after property name.
Error: Parsing vrscene-file error. File “/root/.ChaosGroup/vray-cloud/work/drone/jobs/99698851/1/scene.vrscene” at line 103908: expected a “=” after property name.
at /drone/node_modules/json-ws/lib/client/transports/http.js:61:26
at processTicksAndRejections (internal/process/task_queues.js:95:5)​
Could you please send us the Job ID/URL?
You can get it from the browser-address bar, when you are on the rendering-page f.e. https://cloud.chaos.com/jobs/JPxQo3udJPIAA-jZ
Also, would you please confirm the exact Host App and V-Ray versions that you are using?
Thanks in advance.
year sure, here you go.
Address
https://cloud.chaos.com/jobs/KZkRn5xcDd62eZHO
Maya 2024.1
V-Ray 6 for Maya, update 1
(v6.10.10, revision 32170 from Jul 10 2023)
Hi, @stezza !
Chaos Scatter is supported in Chaos Cloud and the official V-Ray 6 for Maya Update 1 release.
I checked your cloud job. I can see you are using a nightly build which unfortunately introduced some exporter issues. Bear in mind nightlies are not always stable which is the case.
While we are working on fixing the issue in the internal builds, I would recommend using the official V-Ray 6 for Maya Update 1 release. If you still want to stick to using a nightly build, you can take those up to (v6.10.10, revision 32142 from Jun 20 2023).​
Yeah thats cool, thanks for the advise..Cheers.
