Any ideia what this can be or what is causing this error? I’m getting this error only on 2 frames of a 60 frames sequence. The same frames locally renders just fine either in IPR or in bucket (reduced max samples and lower threshold for the sake of speed).
Error log:
2020-08-31 13:21:34: 0: STDOUT: [2020/Aug/31|13:21:34] [24221 MB] Rendering image…: 68.66% [ 3h 1m 10.1s] [ 1h 22m 42.0s est] [8705 MB resman] [1150 MB texman]
2020-08-31 13:21:35: 0: STDOUT: [2020/Aug/31|13:21:34] [24221 MB] error: Unhandled exception: Rendering region (1980,384)-(1992,396); last marker is at line 4220, file “D:\cgrepo\vray\vray\src\vrayrenderer.cpp”: Preparing global light manager
2020-08-31 13:21:35: 0: STDOUT: [2020/Aug/31|13:21:34] [24221 MB] error: Unhandled exception: Rendering region (1968,420)-(1980,432); last marker is at line 4220, file “D:\cgrepo\vray\vray\src\vrayrenderer.cpp”: Preparing global light manager
2020-08-31 13:21:35: 0: STDOUT: [2020/Aug/31|13:21:34] [24221 MB] error: Unhandled exception: Rendering region (1968,432)-(1980,444); last marker is at line 4220, file “D:\cgrepo\vray\vray\src\vrayrenderer.cpp”: Preparing global light manager
2020-08-31 13:21:35: 0: STDOUT: [2020/Aug/31|13:21:34] [24221 MB] error: Unhandled exception: Rendering region (1968,396)-(1980,408 ); last marker is at line 4220, file “D:\cgrepo\vray\vray\src\vrayrenderer.cpp”: Preparing global light manager
2020-08-31 13:21:35: 0: STDOUT: [2020/Aug/31|13:21:34] [24221 MB] error: Unhandled exception: Rendering region (1968,408 )-(1980,420); last marker is at line 4220, file “D:\cgrepo\vray\vray\src\vrayrenderer.cpp”: Preparing global light manager
2020-08-31 13:21:35: 0: STDOUT: [2020/Aug/31|13:21:35] [23813 MB] Number of raycasts: 46646339490 (25098.11 per pixel)
2020-08-31 13:21:35: 0: STDOUT: [2020/Aug/31|13:21:35] [23813 MB] Camera rays: 159294632 (85.71 per pixel)
2020-08-31 13:21:35: 0: STDOUT: [2020/Aug/31|13:21:35] [23813 MB] Shadow rays: 2016088959 (1084.76 per pixel)
2020-08-31 13:21:35: 0: STDOUT: [2020/Aug/31|13:21:35] [23813 MB] GI rays: 1655703471 (890.85 per pixel)
2020-08-31 13:21:35: 0: STDOUT: [2020/Aug/31|13:21:35] [23813 MB] Reflection rays: 2841764692 (1529.01 per pixel)
2020-08-31 13:21:35: 0: STDOUT: [2020/Aug/31|13:21:35] [23813 MB] Refraction rays: 98501668 (53.00 per pixel)
2020-08-31 13:21:35: 0: STDOUT: [2020/Aug/31|13:21:35] [23813 MB] Unshaded rays: 40222365889 (21641.68 per pixel)
2020-08-31 13:21:35: 0: STDOUT: [2020/Aug/31|13:21:35] [23813 MB] Light cache utilization: 63.84%
2020-08-31 13:21:35: 0: STDOUT: [2020/Aug/31|13:21:35] [23813 MB] Number of light evaluations: 4084748981 (2197.80 per pixel)
2020-08-31 13:21:35: 0: STDOUT: [2020/Aug/31|13:21:35] [23813 MB] Maximum memory usage for resman: 10235.29 MB
2020-08-31 13:21:35: 0: Done executing plugin command of type ‘Render Task’
2020-08-31 13:21:35: 0: An exception occurred: [2020/Aug/31|13:21:34] [24221 MB] error: Unhandled exception: Rendering region (1980,384)-(1992,396); last marker is at line 4220, file “D:\cgrepo\vray\vray\src\vrayrenderer.cpp”: Preparing global light manager
2020-08-31 13:21:35: at Deadline.Plugins.PluginWrapper.RenderTasks(String taskId, Int32 startFrame, Int32 endFrame, String& outMessage, AbortLevel& abortLevel) (Deadline.Plugins.RenderPluginException)
Details
Date: 08/31/2020 13:21:38
Frames: 1065
Elapsed Time: 00:03:06:17
Job Submit Date: 08/29/2020 22:08:35
Job User: danastacio
Average RAM Usage: 32002035712 (24%)
Peak RAM Usage: 79112130560 (58%)
Average CPU Usage: 98%
Peak CPU Usage: 100%
Used CPU Clocks (x10^6 cycles): 1589614848
Total CPU Clocks (x10^6 cycles): 1622055884
