I have a file I need to get rendered pretty urgently, however when I upload to pixelplow render farm i’m getting the following error:
10/26/2015 3:56:48 AM; MENTAL RAY LOG: WARNING API 0.0 10 MB warn 302021: iray_layered_material_max.mi, line 977: while defining phenomenon declaration “iray_layered_material_phen_2”: type conflict: “Map” is a color texture, interface “layer0_bump_map” is a shader
10/26/2015 3:56:49 AM; MENTAL RAY LOG: WARNING API 0.0 10 MB warn 302021: iray_layered_material_max.mi, line 981: while defining phenomenon declaration “iray_layered_material_phen_2”: type conflict: “Map” is a color texture, interface “layer1_bump_map” is a shader
10/26/2015 3:56:49 AM; MENTAL RAY LOG: WARNING API 0.0 10 MB warn 302021: iray_layered_material_max.mi, line 985: while defining phenomenon declaration “iray_layered_material_phen_2”: type conflict: “Map” is a color texture, interface “layer2_bump_map” is a shader
10/26/2015 3:56:49 AM; MENTAL RAY LOG: WARNING API 0.0 10 MB warn 302021: iray_layered_material_max.mi, line 989: while defining phenomenon declaration “iray_layered_material_phen_2”: type conflict: “Map” is a color texture, interface “layer3_bump_map” is a shader
10/26/2015 3:56:49 AM; MENTAL RAY LOG: WARNING API 0.0 10 MB warn 302021: iray_layered_material_max.mi, line 993: while defining phenomenon declaration “iray_layered_material_phen_2”: type conflict: “Map” is a color texture, interface “layer4_bump_map” is a shader
10/26/2015 3:56:49 AM; MENTAL RAY LOG: WARNING API 0.0 10 MB warn 302021: iray_layered_material_max.mi, line 997: while defining phenomenon declaration “iray_layered_material_phen_2”: type conflict: “Map” is a color texture, interface “layer5_bump_map” is a shader
10/26/2015 3:56:49 AM; MENTAL RAY LOG: WARNING API 0.0 10 MB warn 302021: iray_layered_material_max.mi, line 1001: while defining phenomenon declaration “iray_layered_material_phen_2”: type conflict: “Map” is a color texture, interface “layer6_bump_map” is a shader
10/26/2015 3:56:49 AM; MENTAL RAY LOG: WARNING API 0.0 10 MB warn 302021: iray_layered_material_max.mi, line 1005: while defining phenomenon declaration “iray_layered_material_phen_2”: type conflict: “Map” is a color texture, interface “layer7_bump_map” is a shader
10/26/2015 3:57:07 AM; Error rendering frame 20: Render Error (Initializing Renderer)
10/26/2015 3:57:08 AM; Job Completed with Error(s) - see above
10/26/2015 3:57:08 AM; Job Completed with Warning(s) - see above
10/26/2015 3:57:18 AM; Error occured while rendering job.
c:\Program Files (x86)\SquidNetSoftware\SquidNet\webroot\public>IF NOT ERRORLEVEL 0 set retvar=3
My scene has no IRay materials, all materials are corona materials. The scene was converted from Vray using the corona converter script. The scene renders fine locally and also with a different render farm.
I’ve spoken to Pixelplow who have told me they’re unable to assist as corona doesnt kick out any error logs, so have forwarded me to yourselves. I am aware that they are using the beta of 1.3 whereas i’m using 1.2. Could this be the issue. Also when I upload i’m ticking the distributed rendering settings in the render setup dialog.
Cheers
Mik.
