Render Farm Specification Help
Hi guys!
I try to find good render farm specification and equipment description which I will use in my work.
I’m designer, use 3Ds Max and don’t understand how to choose best solution for my render farm.
In this I’m working on PC with Ryzen 7 1700 and it’s perfomance not enough.
I have budget 10k $, Please help me.
You can buy Threadripper 2990WX as your workstation, it’s 4 times faster than your current Ryzen.
2990WX + 64GB ram + 1tb SSD + High end GPU + Everything =<5k $
You can then buy another without some fancy stuff needed for workstation for well under 4k. The total would give you 8 times faster rendering times than you have now.
Alternatively, you can buy unofficial grey-market xeons for the second rendering node (but not WS), but it’s not for beginner and you can’t re-purpose it meaningfully as workstation should you need to do so (your PC breaks down, your studio gets another colleague,etc.. ).
I don’t suggest this route to you, I am just writing it here before some smart-ass comes and mentions it as the only correct solution.
Hello, you haven’t said in what environment you will use this “farm”? Are you a freelancer/single user or will there be more people accessing this farm like a studio environment?
From what you wrote I understand you work now on a Ryzen 1700? If you indeed are a single user/freelancer I would not suggest investing all your budget in building a rendering farm. If I was in your place I’d rather invest in a more powerful workstation since 90% of your time you will be rendering interactive and you will have more use of a powerful workstation + some nodes then your current machine + more nodes. With 10k depending on the market where you buy your stuff you could have 5k left for a 32 core 2990wx and 2 rendering nodes for the other 5k, for example 2x dual 24C Xeon Platinums from Ebay. You could even get 3 of those but then you would need to go for something less powerful as your main horse. Something like a 1950x/2950x even which is still more then double the performance of your current 1700 Ryzen pc.
On the other hand if you just want to invest this money in a farm then you could get 4x dual 24C Xeon Platinums with 32gb ram each or 3x with 64gb each. Again this is just pure speculation since I don’t know where you buy your equipment and what are the prices in your country.
Side note for all those freelancers out there asking if they should build a rendering farm. For low-end rendering farm you need at least 15-20k$. For someone who is just starting that’s a huge investment and I would always advise to build a good workstation first. If you are doing animation heavy work you would need even more then the 15-20k… Recently a friend of mine who is a freelancer told me about current online render farm service pricing and I was astonished how cheap they are now.
I won’t mention any names since I am not promoting anyone but for all you out there who plan to invest in a farm take a look first on the online prices you won’t believe how cheap they are lately.
All of a sudden the 15-20k you planed to invest can serve you well over 3-4 years of online rendering while your equipment value over that time span can go as low as 30% of the initial investment… So think about it well!
Render farms are cheaper lately, what else can they do with all the GPU renderers getting foothold :- ).
I was heavy Rebus user, but for me local render farm brings further efficiency by rendering even previews quickly and with high-quality. I render preview at 4k, down-res to 2k and send client a superior looking image. The time it takes is still faster then sending it off to farm unless I want to pay the premium price for instant start in queue.
But even with 200 physical cores (400 HT) I still render overnight my biggest stills… Corona can quite slow.
Thank you for your answer. Can I use 2990WX + 64GB ram + 1tb SSD + High end GPU new RTX 2080? would it give me X times faster rendering?
Only the CPU part would increase your rendering times. So workstation + Nodes.
Choice of GPU depends how much you’re also gonna do GPU rendering (Fstorm, Vray-GPU, Unreal4 engine,..) and how big are you scenes (3dsMax viewport requires a lot of VRAM, for example, my scenes need often 10 GB +/- Vram, so GPUs with 8GB like 1070/1080/2080 are not enough and I need Titan/1080ti/2080ti which have 11/12GB Vram.
So if you only going to do 3dsMax/Corona, get 1080ti for the 11GB Vram. 3dsMax viewport can be very freezy/laggy when it runs out of memory.
If you also gonna do GPU rendering in future, get RTX 2080/2080ti. The latter is super expensive.
V_1 = 14k $
intel xeon gold 6148
asus ws c621e sage
asus gtx 1080ti strix
kingston ecc reg 192gb 2666mhz (32*6)
wd blue 2tb ssd
wd blue 2tb ssd
wd black 1tb m.2 ssd
toshiba x300 6tb
toshiba x300 6tb
cooler master v1200w
cooler master case cosmos II
Noctua NH-U14S DX-3647
V_2 = 9k $
intel xeon gold 5115
asus ws c621e sage
kingston ecc reg 128gb 2666mhz (32*4)
wd blue 2tb ssd
toshiba x300 6tb
toshiba x300 6tb
What you can say about this variants? One IT company prepossessed this variants.
Well, as you can see it’s lot more money, esp. when buying official Xeons. I don’t know whose budget this is, if it’s your company, it’s their call :- ).
Both those would be slower than 2990WX in every aspect.
