Render finished - Stuck Applying glare
I just finished a render with resolution at 23031 x 8858. Took 8 hours on my workstation. But it’s been stuck on applying glare for about an hour now. It didn’t save the passes and it’s not in my VFB history either. So I would have to re-render the thing. I didn’t have any problems rendering it. Any suggestions?
probably the GPU accelaration of the glare that is stuck with this kind of resolution…
Ok thx. So I’ll just turn off lens effects then before rendering in case it gets stuck there again. I can always turn it on, just needs to be saved first. It’s weird though I have a RTX 2080ti should be fine no?
Yeh Ive been rendering at 15k with lens fx and it takes 20mins ish to get the glare applied. Its a massive pain trying get lens fx dialed in at those resolutions.
So it seems that when I try to apply the Lens Effects after the render finished it just crashes.
