Giving an example.
Last night I left a render at 9% noise level and 47 passes. This morning was at 9% noise level and 50 passes. The CPU was at 8%.
My machine the same.
It starts well and but then after a couple of hours it seems that Corona just stops caring. I don’t know if it helps, but when using time limit, the Estimated remaining time is stuck it doesn’t go down.
Well, the problem maybe related to Xrefs somehow.
If you want to find a reson then try to disable half of Xrefs, then check if problem is still there. If not - problem was in disabled Xrefs, so you can enable them and disable half of that half and so on, until you will find a problem.
And Stop in VFB should apply denoise when it’s pressed. After denoise it should stop. It doesn’t?
That is why I don’t think the problem are the Xref.
First, the render starts really well. Like after 2 hours I am already around 12%. Then when I press stop the render, the render doesn’t stop and apply the denoising. Also, if I am using the time limit it starts well, so why after a couple of hours it stops working?
I think that if the problem were the Xrefs the render wouldn’t even start.
Yes, so as you can imagine is quite a pain. Having to save VFB, close 3ds Max, open again all those Xref and resume render.
And that is what to me doesn’t make sense. How is possible that only after a couple of hours the Corona stops working? And if you look at it, everything is normal. The smiley face keeps moving, the numbers keeps going up and down, is only you see the same Pass number and noise level, that you realize something is wrong. And then you press stop the render, and it simply ignores you. It doesn’t stop, it doesn’t apply the denoising.
To find a reason you can do some things (if you can’t share a scene).
At first disable all Xrefs and try to render. If problem is gone - then some Xref generating it, if not - you need to reset CoronaSettings and render again.
I’m not telling that if the problem is in Xref then it’s not a bug definetely it is. But you need to share a scene or investigate…
I know only one method to find a reason - exclude suspects. Maybe somebody heard about this issue and will post here some advice, but I didn’t unfortunately.
I know I am doing that. But, no I can’t share the scene. Besides the scene is already 25GB, so is quite a lot. I will share here what I find. Thanks Nik for your moral support.
Can you send me Corona logs? They should be in C:\Users\Your_Username\AppData\Local\Autodesk\3dsMax\Some_Max_Version\ENU\en-US\plugcfg\corona
Is your CPU still on 100% when the render gets stuck?
It could also help to have a look at sampling focus render element, just in case adaptivity is doing something weird.
I am sending the logs. The last log is another scene I rendered overnight, but if helps I can render the scene that is giving me issues tonight with the Sampling Focus render elements as you mentioned.
No, the CPU is like 8% when the render gets stuck, which shows me that Corona\3ds Max isn’t rendering. That is what I find really weird.
