Render grayscale
Is it possible to force a grayscale render ? A render without textures - but all the shadows looking right ?
I would like to use this for laying under a ‘raw’ SU export.
Re: Render grayscale
Where’s an Override Material tickboc in the System tab which let you select a simple colour to override all materials in your scene to produce a clay render.
I tried that one - changed it to white - but then the model got to bright - hmm gray might work…
In the framebuffer, there’s a little circle button (it looks gray) at the top next to the Save button…click that and you’ll get a grayscale image
You can force V-ray not to use any textures by unchecking the Maps option in Global Switches.
