I am using DR and have one pc with license and other one as renderslave.
Scene gets transfered to slave and it renders fine and all is fine.
But then SOMETIMES, I get the error message written above and slave stops responding. It happens unexpectedly and I cannot find the cause. Any idea?
After this message, I shut the vray DR spwaner manually on the slave and manually start it again and it starts responding again.
It happens 10-15 times during the day. Anyone knows solution?
Vray just uses ping to check if the host is available.
You could check the Windows Event-logs on both computers to see if there’s a network-related problem. It could also be a problem with your router/switch.
hi martin
it seems u&me having endless DR problems ehehe
I had this problem with max9 and solved it. I wrote this in another post.
let me explain here.
I discovered that this happens because of 2 non-working ram slots.
and it is strange that it happened only SOMETIMES.
after a mysterious and painful day trying to dicover problem, I found that 2rams are not working properly.
and then I thought “maybe it is not rams but ram ports” and I was right.
2 ram ports on my motherboard died and causing this problem.
after I removed rams from that ports (they are empty), problem is gone.
here is how I did :
(btw I am a hardware dumb so I might be advising a funny way but this is how I made it eheh)
I removed all rams and plugged one pair and enabled the memory test of BIOS at the beginning when first open pc.
so when rams pass the test, windows started load.
then I removed this pair, and put other pair in their own slot. repeated same. they passed test.
3rd pair couldnot pass test and windows did not load. So I thought I found guilty RAMS.
but then suddenly I thought “maybe it is not RAMS but RAM ports they are sitting on”
so I put the guilty RAMS in one of the already tested slots. and windows did load.
so unfortunately I learned that my RAM slots are dead.
I was sad, if it was only RAMS easy to replace. but when it is slots, you can do nothing. you just have to learn to work with less ram
i got this problem on friday, but solved it. instead of starting all the vrayspawner services at once, i started them one at a time. and waited untill the one was finished and added before the other..
I too have seen this and have found that adding the license server IP and name to the hosts file on each render node gives the node the fastest possible way to find it’s way back. It has helped reduced the occurances of nodes dropping off. The host file is in C:\windows\system32\drivers\etc. Open it in notepad and there are instruction on how to add addresses remarked inside the file.
