Render host lbn*** (192.168.0.235) is not responding
I just finish to installed a small render farm.
DR is not working anymore after rebooting the main workstation.
I first need to restart all slave to get is running again.
To reproduced the error I follow theses steps:
- Initiale state: Slave and workstation are on and DR is rendering allright
- Shut down the mainworkstation (where is the dongle and the license is) while the slave are still on (but not rendering)
- Start the workstation
- Start DR rendering → Render host lbn*** (192.168.0.235) is not responding…
To get it running, I first need to restart all the slave, it’s like the license server can’t be access if the slave are not turn on after the main workstation.
But it is working fine with Backburner, even if the workstation is restarted without restarting the slave!
How can I solve this issues?
Please, can you give at least a direction to try to solve this.
I will move the dongle and license server to one of the server then change the host IP on pone of the slave to see if it solve the problem.
Please find thereafter some more information:
For testing pupose and to try to narrow the source of the problem I disconnected the RJ45 on my workstation, then plug it again.
This disconnection of network make the render slave unavailable in Vray. I can ping all slave, I can access to the slave using remote desktop, but I can render using distributed rendering!
I will appreciate if I can get a support on this issues!
First of all - which Vray/3DSMax version is that.
After the restart, make sure that Vray License server is started.
By the way how do you start Vray License Server and VraySpanwer, manually or as a windows service?
If you have antivirus/antispam/firewall software on the workstation make sure that they do not block the connection to Vray License Server.
Vray2.4
max 2014
Vray license server is running because the workstation render fine, only the slave are not working
License server is started as service
Spawner is started on the slave as a service
Antivirus and firewall off on the workstation do not solve the problem.
What next?
Hello again,
It seems that this is a bug which has been already fixed in Vray 3.x version.
There is no fix for version 2.x so far but there is a very easy workaround - just make sure that Restart Slave On Render End checkbox is ON.
With that option checked the spawner will be automatically restarted after each render end, so if for some reason Vray spawner loses its license it will print “not responding” error then it will restart itself and it will join successfully the next job.
thanks,
That solve the issues.
Unfortunatly, it was working but not any more.
If a DR job is cancel, even when "On render End checkbox "is ON, sometime 9 host are not responding, somedine, 7, sometime 8… are not responding any more.
I need to restart all the host to be able to get all node running fine again.
Hi
We have recently moved to max 2014sp5 + Vray3.06, but just before that the situation was exactly as yours.
It’s always a good point with windows to restart the all machines from time to time. We have used restart either the workstations or the nodes. I feel that you will have to accept this workaround, since it is simple and clear. :wink:
Regards,
Dimitar
Thanks,
but I would like to used the slave for fine tuning light, material… By restarting the slave everytime I canceled a render means that I’m not going to used them at all.
If possible I would like to avoid upgrading because the farm is not powerfull (bi quad 5420), license price are not worth it, because it is going to cost me more than the 16 server themselves.
