Render ID ?
How come that the Render ID is not being saved at all. The directory where all the other layers are being placed in is accessable. All the layers like alpha, diffuse, reflect… and so on are being saved as wanted. Render ID isnt. Is there a trick to it. If i look at the Render ID frame during rendering in the VFB window it seems fine, besides not being saved.
Thx in advance
Ralf
Found the issue…
Dis a thorough search and voila…
http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=14078&highlight=render
might help others
Just to be sure, the Render ID is the same as the Object ID in scanline, right?
ralf
Re: Found the issue…
Nope. The render ID is a number assigned to the object internally by the renderer. For example, render IDs generated by the scanline renderer will be different from those generated by V-Ray. Object IDs, on the other hand, are specified by the user in the Node Properties of objects and are the same no matter which renderer is used.
