is there a way to render the irrad map but not the frame (for when I’m creating the Irrad. map) I want to render a final quality later so I really don’t need the renderings when I’m using incremental add (except to maby check eatch frame)
at the moment I have the settins:
AA fixted rate (defult)
image size half origonal
Min/max to sample more the full size image (ends up being the same size)
the idea is that I can create the Irradiance map faster if I didn’t have to render the frame after it.
