Render Iterations - Active Shade
I noticed that when I use Active Shade (3ds Max 2018.2-Vray 3.60.1 RT) the Open Subdiv Render Iterations are not applied. This appears to be the case with only Vray RT - other renderers (ART, Arnold, etc…) do so. Is this intended behavior with Vray?
Thank you
Daf
This seems to work fine in here on a simple scene. Can you attach an example file?
Thanks for the reply. You are right, in a simple scene it works. Must be something specific to my scene. I will investigate and report back if it still appears to be Vray related. Thanks!!
