render just freezes ?
Hi guys, just got a big problem.
need to render out an image sequence of 200 images of an architectural masterplan.
i prerendered the light cache and irradiance map (every 10th frame).
when i try to render the final sequence the render just freezes at image 77 (sometimes 76 or later…) the task manager says max still uses 50 % but nothing happens on the render anymore.
plus, i am not able to stop the render. it just freezes.
tom schuelke said to me that perhaps a vraydisplacement over a max displacement could be the problem, but i already checked that by convertinbg the max displacement to an editable poly.
i really have no idea what happens here, because it also crashes with an override material and by rendering the gi by frame.
here is frame 77 of the scene.
just the vraysun and sky scene size is around 58 mb. nothing special i think.
the streets are the vraydisplacement, the topography is the max displacement.
thanks for all suggestions ! :roll:
Are you using 64-bit version of V-Ray RC3?
yes, exactly.
and i just found out, it´s the vraydisplacement on the forest that causes the crash, but i don´t have a clue how to solve this.
tried to create a proxy out of the forest object, but then, the displacement is gone…
You can email me to vlado@chaosgroup.com and we’ll see what can be done about it.
here is a screenshot of the displacement :
and this is the used material:
http://www.vray-materials.de/all\_materials.php?mat=1065
we also have this problem.. can you please check you email vlado..
is this a compatibility bug together with rc3 and win64 ?
Hallo Vlado,
i had some contact with arch4d, who´s deadline beginns to come near now.
I thougt for a while it could be a problem of max displacement together with vraydisplacement .
Overall, i have the feeling, that max9 and win64 bit dont work very good together untill now.
I am not sure, if arch4d allready was able to mail to you his Scene. So ill do it for him now.
maybe ( if not you, who else could ? :wink: ) you can help him.
thank you in arch4d´s name.
greetings, Tom
solved it for now, thank you all ! :lol:
surprise, surprise with decreasing the output resolution it render out just fine.
but i´ll keep an eye on it and try to find out what´s going on here…
