Hello
“render marked takes to pictureviewer” renders always the same take (the actually marked take) instead of switching trough all marked takes.
(Daily Build 2023-01-23)
Hello
Hi Beck,
I have this issue too, it is here since Corona 9. There is a workaround, you have to set the C4D Picture Viewer as the default Framebuffer in Corona settings, like this :
Ok, thank you John.
I have this problem only since the last daily build 2023-01-23 (C4D R25). But i will try your workaround.
This setting seems not to be the problem, because this was already set to “C4D picture viewer” in my corona settings.
Thank you anyway
Can confirm, I had the issue today with Corona v9. In fact I had the two results, one scene where it worked and the other one it failed to change the active take. In the latter the marked takes were the children of a parent take, which itself is parented to the Main take. I don’t have the time to dig further but it could be related to this.
I had this issue again tonight, before launching a big batch of renders. It isn’t specific to Corona since the issue occurs with the basic Viewport Renderer too, and not hardware-specific since it happens on two different workstation.
Then a simple Google Search leads me too a post on Core4D forum from 2021 that confirmed that the issue is 01) old 02) on Cinema 4D side :
(the post : https://www.core4d.com/ipb/forums/topic/115341-takes-system-bug/)
So I’ve ran a close inspection of the overriden properties in the Takes Manager, and after deleting just the following little f*cker, everything works again !
I don’t know if the propertie was tied to a deleted camera, or maybe a deleted Corona Tag, but it seems that the absence of the original data / object / propertie lead to a bug that render the current take over and over ( as many times as there are marked takes if you use the related command ).
