Render Mask Problem (image sampler)
Good morning everyone, I have to render only one moving object in the scene. for this I used the SELCTED render mask, but the result is not correct because the previous buffer is not deleted. how can i tell vray to clear the frame buffer after rendering?
thanks for help
Hi, In “System” rollout (V-Ray render settings) there is a drop-down menu called “Previous render”, from which you could specify the behavior.
thank you very much for helping!
