Option (Render Only channels) work not correct with Distribute Render/
On Render nodes Rendering slower because them rendering in full mode, (with GI and etc.)
It visible in frame Buffer during rendering.
Corona Bitmap don’t support (Bercon Maps and Tiles)
and don’t work correctly with Corona Scatter for Density and other options/
There is currently a string option that allows sending “channels only” renders to the render farm:
I think it will be good to have it a bit close to user without messing with strings. May be a checkbox or smth.
we will re-do the UI bit probably when per-render element AA is implemented
