How can I render only some elements, WITHOUT rendering the final image ?
This is not possible for the moment; render elements are a side effect from the normal rendering - they only provide you with additional information generated in the process of the actual render.
You could setup renderpasses for certain render elements.
Thank you vlado.
When you say “for the moment” it means that it is somewhere in the “to-do list” ?
@raymarcher : What do you mean exactly ? I don’t get it.
