Render Organisation
Hello Forum,
so i would like to know how you handle big Projects with a lot of diffrent cameras, Lightning etc. I do have to render about 30 images on a render farm. Has anyboy some advices how to set up so i can send it to the farm? Do i have to set keyframes an change Kamera Lightning etc. via the stage object, or is it possible to feed the Render Manager with all the particular settings? Would be nice to hear some experiences.
Thank you
Christian
The take system is the thing you’re looking for.
Not only can you switch cameras but render settings as well, not to mention pretty much anything in the object manager can be overridden. And at the end, you can just set to render all takes and you’re done.
ok, thank you, time to check the take-system.
One camera > One take
Click on the little grey camera and select your camera
Click on the grey circle > take that must be rendered
Specify a path for rendering like this : scene $camera
Render > Takes > Render marked takes
