I would like to render a white high glossy material in 3ds max using v-ray… i use HDRI light… what type of material set up i should use. pls help me(Exterior render )
VRayMtl is the material you are looking for. Just set the Reflection Glossiness parameter to a value that suit your needs and that it.
You can also play a bit with BRDF model if you are looking for a more specific effect.
