HI, where is the field in the shader editor to enter a id number for the render pass MatID node to work ? Thanks
Hi @eric_kubiak ,
Is this what you are looking for? If so, you just need to click on the Material Output node and enable Material ID in the Node panel.
r
Thanks a lot !
