Hi, I’m trying to figure out if its possible to make a render pass with only the foam and the splashes, not including the ocean surfaces ?
/stefan
/stefan
You can add a VRayAtmosphere pass and it will do exactly that (note that it this won’t work if you render the particles in Geometry mode).
Also, if you want to just render the particles, then you need to make the simulator not renderable and leave only the particle shader.
I will try that, is there any change of you redoing the ship tutorial with Phonix
3.1 ? ![]()
Yep, we’re working on that right now, so I hope in a couple of days it should be online : )
Sounds great ![]()
