Render probleme
Sharing here my problem.
As you can see, I can’t render properly, the denoise is over…
Do you know why this make some blurry aera on light?
Find here the config + render
Thanks for your time,
Wish you a good day.
Can I have some help please? :d
Super forum …
Hello @Panduru79
The V-Ray Denoiser, when set to ‘Strong’, may make finer details less defined.
In your case, I would recommend to choose a different, more mild preset (Denoiser > Preset). You will have to only use the refresh button under ‘Mode’ (the button right under the ‘Show Denoiser Channel’ in your screenshot) without the need to render again.
Please let me know if this resolves your question.
Finally, I would like to mention, that if you need a more urgent response, sending a message to support@chaosgroup.com would be the best option.
